Hello from Australia
  • Hello from Australia
    Hi
    I hope that most of you can understand English as i really need some help in regards to performance modifications for my beloved E34 535i
    I was wondering how common is it in Deutchland to Supercharge or Turbo my model BMW.
    The availability of either kits is very limited (infact nothing at all) and i would like to gain some more power for my vehicle.
    Don't forget that in Australia we drive on the left hand side and not the right so i'm not sure if that will make a difference in the kits available.
    Would anyone be able to link me to some shops that mail overseas? Either from Deutchland or England.
    Danke
    Chus
    Kris
    Re: Hello from Australia
    Hi Kris.
    First a cordial welcome in our forum. With your E34 problem will be able to help you our user ERICH best. I wish you all time much fun with us here.
    Greeting
      thanks for your warm welcome
        Hi Kris,
        it is not very common to supercharge the E34 in Germany.
        There are a lot of members from Australia on these boards, maybe they can help you out
        bimmer.info
        and
        http://www.bimmerboard.com/forums/e34/
        A lot of people buy parts from USA, as they are much cheaper there than in Australia.
        http://home.earthlink.net/~hainesinutah/bmwvendors/
        BMA is often recommended, I buy usually from Autohaus Arizona.
        BTW: are you BigKriss?
        If so, you know me too, (shogun). And that would be your car
        click me
          Hi Erich
          Nah I'm not BigKriss but i do know him from another forum It seems the internet is a small world
          If supercharging isn't a common modification, what about turbocharging?
          The problem i have is that there is NOTHING in regards to forced induction modifications in this big island
          I have browsed bimmer.info but not much was mentioned about either topic. It seems that it's rare to do that kind of modification. I am also chasing some interior pannels for my car as my ones have peeled (glue has failed). Is there a cheap place i can get these? I got the brown/cream combination.
          Thanks for your help
          Kris
            Do you look for such a thing???
            LOOK
              I used the search engine on bimmer info with 'turbo charging'
              http://www.capa.com.au/eaton.htm
              Eaton superchargers.
              But I would not go for supercharging or turbo. Probably your engine will not last that long, and it has also a lot of km on the clock.
              That nees more extensive and expensive work on the engine.
              How about a chip?
              EAT is always recommended in USA
              click
              Door panel fix is here
              click
              Also visit my website below, a lot of repair tip for E34 and E32.
                Machtpur
                Not quite. That's just the top trim I need the entire toor panel (interior).
                Wish i could remember my deutch. I used to live in Leverkusen in 1986-88 when i was a kid. Can't remember anything now since i had to learn english.
                Scheize
                  this is what i need
                    Do a search for the name Rigmaster on bimmer.info. He has on his farm in USA about 15 E34, some 2002 and other BMW and ships worldwide at good prices and is a reliable source.
                    His real name is Bret Luter.
                    I think also BigKriss might have some parts available, as he an another chap organized something.
                    Also ask in Bimmerboard, some people have spare cars.
                    I only have E32 750iL's and plenty of parts for these cars. At the moment 5 of them.
                      Thanks Erich...that helps heaps
                      In regards to your above post about the EAT chip...i already got one and the performance increase was awesome...
                      Think the first thing i need to do is a AUTO to MANUAL conversion...but that's AU$3000 (about 1500 euro). That should improve my performance
                      Appart from that...what else can be done to improve performance without going the turbo charging route? Camshaft? Cold Air Intake? anything else?
                        You have a speed limit in AUS. So you do not need a high max. speed. I would go for a different differential gear ratio to increase the acceleration. A used diff is normally not that expensive.
                        http://www.e34.de/e34/difftabelle.htm
                        And here you can play a bit around with the numbers
                        http://www.m-forum.de/calc/getriebe/index.html
                        Info:
                        S = Schalter=manual gear
                        A = Automatik = automatic transmission
                        T = Touring
                        TA = Touring Automatik
                        Conversion to manual transmission/gear is shown on my website on the link to Gale's page. He did it on an E32 735.
                        Cold air intake does not help in my opinion. Everyone is saying that the BMW intake system is very good. Except , it makes more noise and you get more dirt into the engine and the MAF.
                          Considering i have the AUTO by the graph you have linked to i should already have the 3.91 gear ratio in my diff. This means that if i get a MANUAL gearbox conversion it will be perfectly matched and will increase my take-off speed.
                          So...i should expect a 0-100km/h time of about 7 sec. That's good enough for me...for the short term
                            Better check once more your differential. The information is for the German specification. Maybe you have a different one installed. For example on my E32 the diff is a version for USA/AUS and Japan, because of speed limits in these countries. Even the 735 E32 in country specification Switzerland has a special diff because of the mountains there.
                            Best is you use the online parts catalog and go thru the different production years with different engines of the E34, and also switch from European version to US version. There are often different parts.
                            RealOEM.com BMW Parts website. This site can be used to look up BMW part numbers and approximate part prices. The Parts are grouped into diagrams and diagrams are grouped into categories and subcategories
                            Here are all US specs
                            and these are the ones for E32, also interesting for you:
                            730 iA from 09/88.......: 4.10
                            730 iA Switzerland......: 3.64
                            730 iA Switzerland from 09/89....: 4.10
                            730 iA Australia /Japan..........: 4.27
                            730 i M60 engine..............: 3.15
                            730 il M60 engine.............: 3.15
                            730 iA M60 engine.............: 3.23
                            730 iAL M60 engine............: 3.23
                            735i..........................: 3.45
                            735 iA........................: 3.45
                            735 iA from 09/88.............: 3.91
                            735 iA Switzerland from 09/89.: 3.91
                            735 iA Australia..............: 3.64
                            735 iA Australia from 9/89....: 3.91
                            735 iA USA / Canada / Japan...: 4.27
                            740iA.........................: 2.93
                            740iAL........................: 2.93
                            750iA.........................: 3.15
                            750iAL........................: 3.15
                            750 iAL USA / Canada / Japan..: 3.64
                              yep....i'm 95% sure that i've got the 3.91 ratio
                              Have a look at the Australian version of the 735i. It has the same gear ratio as the 535i
                              By the way...the door fix that you posted earlier on won't work on my car. The vinyl has peel off on and under the armrest and major parts surrounding that area. On the passanger side i also have a big rip on the arm rest. I need new pannels
                              Are there any BMW Dismantlers in Deutchland that you could recommend i could contact? Prefferably someone with a website?
