DWA Falschalarm durch NAG E34/39/38/31
  • DWA Falschalarm durch NAG E34/39/38/31
    betrifft alle o.g. Modelle bis Bj 06/96. Neigungsalarmgeber ist das Problem. NAG = Neigungs Alarm Geber
    Group 65 65 20 96 Woodcliff Lake, N.J. Jan. 1997
    Sound Systems, Cruise Product Engineering Alarms, Monitors
    SUBJECT: Anti-Theft System (DWA) False Alarm caused by Inclination Sensor (NAG)
    MODEL: 5 Series (E34, E39), 7 Series (E32, E38), 8 Series (E31)
    Situation: The Anti-Theft System (DWA) may sporadically trigger false alarms under two specific circumstances, as follows:
    (A) Approximately 30 seconds after arming DWA
    (B) Sporadically, usually at the same parking location
    Cause: (A) Mechanical reverberation of the inclination sensor (NAG).
    If a door on the vehicle is slammed shut, the mounting of the inclination sensor (NAG) can vibrate. If the alarm is now armed while the sensor is still vibrating, the DWA Control Module stores a random reference position. After the normal delay of approximately 30 seconds, the
    DWA Control Module evaluates the signal from the NAG (which has now quit vibrating) and detects a change of position. This now triggers the alarm.
    (B) External electromagnetic radiation that acts on the inclination sensor.
    Note:
    In both cases, the alarm counter will store the "inclination sensor" as the location that triggered the alarm.
    Vehicles Affected: 5 Series (E34, E39), 7 Series (E32, E38), 8 Series (E31) - vehicles equipped with DWA and produced prior to July 1996.
    Correction: In the event of customer complaint (only affected vehicles equipped with DWA), proceed as follows:
    1. Connect the DIS Tester to the vehicle.
    2. E38, E39 vehicles: Under "Body Electronics", select "ZKE" (Central Body Electronics) and then "Anti-Theft Alarm".
    E31, E32, E34 vehicles: Select "18 Burglar Alarm System".
    3. Select "Service Functions".
    4. Select "DWA Alarm Counter".
    5. If the majority of entries are for the inclination sensor, identify the index number of the sensor itself (index number is printed on the label of the sensor).
    The NAG is mounted on the left- or right-hand side of the luggage compartment, depending on the model. Refer to the appropriate Electrical Troubleshooting Manual (Component Location).
    6. If the inclination sensor (NAG) bears an index number of 10 or lower, it must be replaced with an NAG bearing an index number of 11 or higher.
    Note: Depending on the equipment level of the vehicle, the NAG may be mounted behind various accessories such as CD Changer, Cellular Phone Transceiver, etc.
    Identify the Index Number by using a mirror (see illustration) before removing the NAG.
    Parts Information: Application Part Number Quantity
    E31, E32, E34 65758366214 1
    E38 65718368167 1
    E39 65758367604 1
    Warranty Information: Parts and Labor are reimbursable under the terms of the BMW New Car Limited Warranty of 4 years/50,000 miles.
    Defect Code: 65 75 20 14 00
    Labor Operation: Refer to appropriate Flat Rate Manual
    Labor Allowance: Refer to appropriate Flat Rate Manual
    DWA False Alarm Caused by Inclination Sensor
